Thanks Todd I believe I have that very same press. It just doesn't quite line up straight on center, by about 3/8". Or maybe mine is one size smaller than yours. Ideas are along lines I was thinking. If my press won't get it in, how about a draw through bolt and washers? Removal would be drill the rubber then beat out the outer shell? More?
