when i measure cams, i use two blocks of wood with 'v' cuts in them and bolt on a degree wheel, using dial indicator to measure from lobe to lobe. magentic base on a steel bench, altho i have used just a plate to mount the base.
It may be ugly, but it sure is slow.
Girls comb their hair in rear view mirrors and the boys try to look so hard....
