Looking at the Molnar Technologies crank with 2.100 Chevy sized rod journals and 6.125 scat pro comp I beams.
Is there an off the shelf piston that would work with this set up in combination with magnum style combustion chamber heads that would provide quench and let me run pump gas?
Just bench racing and window shopping parts right now. I like to do my research and math before I start anything.
I was looking at one of these combos a while ago...If I remember correctly Diamond makes a shelf piston for it, but I can't remember 100%, try a search on here.
OR, contact Rod Bloomer from BPE (BPE is his user name on here as well)...He can set you up with custom pistons for a REALLY good deal! And he will take good care of you too!
