I would look into a 2 speed Lenco if I was you, real men doesn't use powerglides
Mafo, that only solves part of the problem, a Lenco is only a 2-speed unit, you still have to have a convertor drive(Bruno/Quickdrive or similar) or clutch/bellhousing combo. A Lenco-drive 2-speed is a stand alone unit that utilizes CS-2 internal components and can have one or more Lenco units bolted to it to make a 3,4 or more speed tranny. In Six-packs case, a PG can be built to take any abuse he can give it, given the weight of the car and 2-speeds is more that adequate. But, if he wants to bite the bullet and take the ultimate step, the Lenco-drive is probably the way to go....
http://www.lencoracing.com/LENCODRIVEMasterPage.html
