Would it help to start adding weight in the front by the gas tank?
it's definitely back heavy. do you remember the rear spring rate? going to plot out the 4 link and see where we are at.
No Tony, I don't remember. There might be a tag on the spring with the rate on it. I don't know if it has enough motor for a taller gear.
