For all of the Negative Nancies chiming in, the car matching the VIN# I posted about IS NOT being represented as a numbers matching car.
"The car matching the VIN# I posted about IS NOT being represented as a numbers matching car."
Fixed!
That's all you had to say since you apparently knew of the car...
Calling names only shows a lack of "real" intelligence. Sorry you are unable to converse with-out doing so.....
