Re: Real 904 power limits
[Re: dOc !]
#1378495
01/30/13 03:46 PM
01/30/13 03:46 PM
Posts: 1,752 detroit area
moderncylinder
detroit area
Quote: --------------------------------------------------------------------------------
ProTrans is 904 guts in a 727 case. True that the 904 parts are the best available, aluminum, billet, etc., but these trans hold up fine at 1000+ HP and 600+ Tq in 3200 to 3800 lb Super Stock cars, ET's in the low 8's to mid 9's. Good parts will live fine.
uNder these applications ... don't they have to be freshed-up every 20 or so passes?
no they dont,, a planetary could break after 100 or so runs though,, so its a good idea to look at it every so often
if you run low line pressure you could burn it up,, a hemi car has about 150-175lbs
