I put a Quickfuel billet throttle plate on a 950 HP. It works fine, but I ended up reusing all the linkage hardware - everything didn't just bolt right on.
Expect to do a little fiddling, but it fits and works great.
Thanks for the input! What do you mean everything didn't just bolt on? Were things misaligned? bolt holes to small? I'm looking for a bolt on base plate to replace my messed with Holley one.
I have the secondary idle speed screw adapter, and the new secondary shaft wasn't long enough for it on the pass side. So I reused the original shaft and the linkage, and the throttle blades IIRC.
Nice piece, no other issues.
remember when you said honey, some day that car is gonna look so good in front of our house
