Re: 273 hi-po has problems, please help....
[Re: beatupcuda]
#1374245
01/22/13 04:09 PM
01/22/13 04:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Have had plugs out, checked cap, wires, rockers, pushrods, timing, carb is new, disassembled anyway, adjusted perfect, choke works fine, cars runs GREAT after warmed up, but still has minor shake, not a miss, like a vacumm leak. sprayed intake & carb no change, checked all bolts..... so that's why i am here,,,,,,, Start car, idles w/choke at 12-1500, no miss no pop, nothing except shaking until warm.....
How did you adjust the choke door when it was cold.. there is a spec(usually a drill size) and that will be a tad lean... then once the door is set then you set the cold idle rpm on the choke cam
Entire Thread
beatupcuda
01/22/13 05:49 PM
dogdays
01/22/13 07:35 PM
beatupcuda
01/22/13 07:45 PM
Mopar-Al
01/22/13 07:51 PM
Kevins493
01/22/13 07:55 PM
beatupcuda
01/22/13 08:00 PM
MR_P_BODY
01/22/13 08:09 PM
moparmanjames
01/22/13 09:54 PM
MR_P_BODY
01/22/13 10:04 PM
JAKE68
01/23/13 12:07 AM
formula S
01/23/13 12:27 AM
beatupcuda
01/24/13 05:12 PM
stumpy
01/24/13 05:41 PM
beatupcuda
01/24/13 05:53 PM
rowin4
01/27/13 12:59 AM
beatupcuda
01/28/13 03:40 PM
formula S
01/29/13 02:34 AM
52savoy
01/29/13 08:07 AM
MR_P_BODY
01/22/13 07:59 PM
Cab_Burge
01/22/13 08:09 PM
GO_Fish
01/25/13 02:09 AM
formula S
01/25/13 07:57 AM
beatupcuda
01/25/13 05:14 PM
formula S
01/26/13 08:03 AM
GO_Fish
01/26/13 12:15 AM
moon
01/25/13 02:50 AM
