Most likely has nothing to do with the converter internals or pump assembly and could be repaired by a good shop. Although depending on where the crack spread to it could be grooving the support bushing. I think in my case above it was a matter of bad driving habits back then. Back dragging the transmission at red lights, and neutral dropping at green lights. A lot of unnecessary stress on the converter...what? I was 20 at the time.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
