I have a 727 transmission that I modified to run a Turbo Action transbrake. I am going to put a Turbo Action "Cheeta" manual shift, reverse pattern valve body back in. Do I need to undo the changes that were made for the transbrake, or will it be OK to leave them as they are and still run the manual valve body? The changes are a shim in the rear band servo, a plug under the accumalator and blocking a hole in the case under the accumalator, I think.
Thanks,
Brian
