Quote: If you use the magnum style gasket with the 360la pan there is a gap that has to be filled. Look at the link posted by someone else above and let me know how you took care of it.
Engine upside/down on stand. Put gasket on block. Put pan on gasket. Loctite and start bolts. Tighten in pattern. Torque accordingly.
That my friend, is how I took care of it. She purr's too. No leaks... Yet.
