The caltracs shuld come with a large diameter AL bushing to replace the rubber bushing/shell that would have come installed in the XHD spring eye. The smaller diameter AL bushing is longer than the big bushing and goes through aand is actually what tightens up against the fron spring hanger. The 'bell crank' should flop with no binding.
What he said.... Do you have the large aluminum bushings? They are a key component to the system.
LemonWedge - Street heavy / Strip ready - 11.07 @ 120
