Quote: If you don't have power, it could be the switch, or the bulkhead connector. Not the starter relay.
I think I am confused, what do you mean if I don't have power? Are you stating that if I don't have power at the ballast resistor then my problem rests with the ignition switch (in the dash) or the firewall bulkhead?
Again, thank you. I am usually not so, errr, slow, I promise.
