They are different. The eng in the Neon is a Chrysler & the Avenger has a Mitsubishi eng.
Incorrect. The NA 2.0l in the 90's Avenger/Sebring/Eclipse/Talon is essentially the same as the 2.0l DOHC used in the 90's Neons with some differences. The turbo 2.0l used in the Eclipse/Talon is a Mitsubishi Motor and shares no parts with the 2.0l NA, in fact they are mounted in opposite directions. The 2.0l turbo has the trans on the passenger's side while the 2.0l NA has it on the driver's side.
That said I think the Eclipse 2.0 Turbo would be an easier swap than a SRT engine since the Avenger/Sebring is basically a stretched out Eclipse/Talon so it should mount right in. Now the electronics to support the engine may be a challenge though.
No longer taking $h!t from anyone!
