I beleive the starter shield pictured above is for a 67-74 A-body.
Attached is the shield I took off my 71 Cuda 340 with T/A steering, Sales code S74. It's a little bent up (I've since straightened it) and the screw was added to hold the rubber on by a previous owner (welded this shut and ground down).
