What was the weather the day/time you tested?
Why did you pull the engine so slow? Build like this should be done at 600 rpm per sec
Slower pull will show more HP most of the time.
I think raw # are closer to what this engine really will make in the car going down the track.
Killer engine anyway you slice it can't wait to see how it runs in the car.
Good job Lavern and Scotty
