none of the brackets will fit?
It depends on what brackets, some the early alternator brackest had two holes in them , non air conditioning cars at least, so you could use it on both the low decks and high decks Some of the BB water pump housings have the bolt boss located in different locations so the alternatot bracket needs to match the water pump You can make the trianagle alternator bracket out of some flat steel or aluminum
