Car had no pump shot so I swapped an Eddy 625 donor carb. Had to rehab it , but it ran awesone. Warmed it up and removed my gas can supply. With the fuel bowl filled I loaded up my son and went up the driveway and around the circular drive. I was shocked at the response.
Got the the top of the driveway and had to do a powerbrake. Immediately started spinning and sliding sideways!
I let out and ran out of gas!
This thing will Rock.
Today I pulled the tank and got about 8 gallons on brown Stink out of the tank. However, tank was not scaley inside. I pulled the Sendeer and pressure washed in and out. Found a new sock on the shelf and will get her running on her own tomorrow.
Today we also drained the trans and adjusted the bands.
Reomved the tow hitch and assessed the brakes.... It had pedal but leaky cylinders.
Did a nice Rock Auto order to service the brakes. I coulda scabbed enough parts from my Cuda project but $150 got me all brake shoes/cylinders/hardware and hoses plus a set of shocks..WTF This thing will be driveable with little.
