Quote: IMO, I'd say the MAX WEDGE pan has more potential than the big-block A-body pan (in general the a-body crowd is "cheap" & the #187 c-body pan works). Also, the number of "stock" anal restoration of MAX WEDGE & clone early b-bodies has to outnumber the quantitiy of a-bodies treated to the same.
Even the stock early '62-'65 b-body pan is getting hard to find - easy solution "upgrade" to the MAX WEDGE apan.
