Quote: For splicing I use a method we had where I used to work called mousing sp?
You take a few strands of the same wire you're splicing and wrap it tightly around the joint, takes some practice but helps keep the joint from moving as you solder.
Joe
Brilliant. That's always my biggest problem. Thank you!
