Used a Flex-a-Lite 480 dual puller setup on mine.
Either the 480 or 490 has the controller included with the kit - one does and one doesn't, but the fan assemblies are the same. Fits perfect on the 26" core radiator, but had to make some brackets from some flat stock and used some 10-24 or 1/4-20 bolts to attach fan to existing shroud mounts on rad. Dual fans allowed room for the slightly deeper nose on the March WP pulley.
Controller makes for slow, smooth startup on fans.
Temp sensor inserted into fins on rad. Controller on rad yoke on driver's side (trunk battery). Power comes from distribution/fuse box on firewall (from an 80's Maxima) - power there comes from alternator.
Not a cheap setup, by any means, but looks nice.
Sorry, no pics right now.
