3200lb 440RB 12.5-1 mopar 620 cam TCI 9" converter with 4:88 gear in a 64 Dodge went 10.60's-10.70's this was in the late 80's using the TRW piston stock rods and crank! Heads even used the stock steel valves.....was a pretty common combo that just worked
