Hey Rebel,
You are correct this is on the Demon. At this point I am not really attempting to lower the ET. I think that the new parts I have will hopefully lower the et. However if it doesn't I am not overly concerned. I am more interested in consistency and I race the car mainly in Super Street/ Hot Rod (10:90 index - 11:10 where I am) so I am already way faster than I am required to be. However the main reason for the change is I raised the engine 3/8 of an inch in the chassis and I am installing an under carb throttle stop. With theses changes I can no longer fit all of this under the six pack hood scoop and still run a decent air cleaner.
