Well that is interesting - so is it supposed to come on when the socket is tilted backward then? If it doesn't do that regardless of the direction I'm tilting it in I can assume its a bad switch then?
I looked on the underside of the deck/trunk lid & didn't see anywhere obvious it mounted, I'll look again. When mounted does the bulb face ft or rear of car?
Thanks for the info, much appreciated.
