Hi all,cars a satellite -
got around to installing the rear bumper & taillights, ran the main mid body wire loom to the drivers side kick panel.
After staring at wiring diagrams I've got some questions, hope you guys can help:
what activates the trunk light power? I noticed I couldn't get power from the center pin of the socket no matter how I bench tested it. I assumed its just a standard single pin socket but perhaps not???
Where does the trunk light mount, bottom of package tray, somewhere else?
Is the loom that connects to the left rear side of the tail light harness & runs to the drivers tow kick the only one running to the rear?
Does that one connect to the dash loom?
Are the majority of the remaining circuits coming off of the dash loom & then the engine & front lighting loom connected to / thru the firewall block?
Oh yeah, the license plate light - I think I have the bracket but no light - any pic's of whats needed for a 71?
I've been staring at these diagrams for a while & trying to figure out if I'm missing a loom or something. I do have the front loom, an engine harness & two dash looms.
FYI - I didn't disassemble the car so reassembly is challenging.
Thanks for any help!
Evan
