Re: How Many Times B4 Replacing Spark Plugs
[Re: YO7_A66]
#1325050
10/23/12 10:34 PM
10/23/12 10:34 PM
Posts: 43,219 Bend,OR USA
Cab_Burge
How many times do you pull your spark plugs (for reading, or for cleaning, etc.) before you worry about the spark plug seals not sealing anymore? Is this even an issue?
My 2$ NGK spark plugs are no longer available and the replacement is 8$ each now. I want to reset the gap but I am first curious about the above. If I can keep pulling my cheapies out then I will, but I am not sure if the spark plug seals are good over and over again. Thanks
I have reused the stock passsenger car spark plug gasket,seals, many, many times without problems I owned and flew a airplane for a number of years, it had copper spark plug gaskets and you where suppose to replace them anytime you removed the spark plugs. I learned later that you can aneal them(copper) and reuse them legally and safely
