I'm lazy, when I did the frame all the following was done: brake lines, master cylinder, disc brakes, rack and pinion, bed floor, fuel tank, and steering shaft.
Here's what I had to fab up to make it work: mate the steering shaft, move the motor back and make mounts cab, engine and transmission, hang a brake pedal.
It time to make a build thread for my pick up.
56 Plaza 63 D100 step side 67 Coronet, 68 Roadrunner, 69 Super Bees, 69 Coronet 500 convertible, 70 Roadrunner Post, 79 D150 360, and a severe case of Mopar a,d,d
