The best place for the fuel pressure gauge is between the barrel valve and distribution block, you want to know what pressure the injectors are seeing and not what the pump is putting out.
Not sure how to do that? The barrel valve and distribution block is a one piece unit.
I just put a T in line to my nozzle. The hose by my radiator hose goes to my memory fuel psi guage.
I got a great deal on my injection stuff. After buying another pump and nozzle jets and other misc, I still was WAY under new. Shop around
