just checking over car today and noticed a little drip of fuel on the ground underneath the trunk after i warmed up the car. checked all fitting ect... found out when pump runs (blue holley) there is fuel pouring out of the 2 little pressure relief holes. right where the 2 screws and two nuts are holding the motor in. any way i can fix this pump has been rebuilt 3 or 4 times.. took it all apart and cleaned it but still fuel pouring out of it
