see this post for some pictures.
https://board.moparts.org/ubbthreads/show...e=1#Post4738647 For that best look here is my 2 cents. Transtar euro clear classic not the speed clear.
Second when you wet sand use only meguiars 1500 and 2500 unigrit paper. Get paper wet and let soak 1 hr before using.
Use a wool pad and 3m heavy cut but dont try and make it shine just buff out the 2500 grit it will still look somewhat dull. next use meguiars med cut on a foam pad. clean your pad often by spurring it with it spinning fast and rubbing a metal object like can opener across it. Then use Menzurna final polish and soft foam pad for final buff. It will look like a mirror. See pics in above post.
