http://aeromotiveinc.com/wp-content/uploads/2009/12/11202.pdf
I don't see where you plumbed the return line off the pump itself, just on the other side of the motor.
Fuel line is too small as well. They recommend -10, I use -12 inlet and -10 all the way to the regulator. Works great thus far. Good luck.
