Well I'm making progress on the 55 pick up. I have the triangulated rear suspension in and have the Dakota front clip tacked on. I'm going to fit the gen III Hemi engine, transmission, cab and fenders in place before I do the final weld on the Dakota clip. I tried fitting the engine and transmission this afternoon. It' going to be a tight fit. The engine mounts need to be moved back so the pan will clear the crossmember.
