Re: E Body Dash Pad Replacement.
[Re: mrob]
#1306272
09/18/12 09:23 PM
09/18/12 09:23 PM
Posts: 2,179 Walton, Indiana
TimS
Walton, Indiana
Here's a brief overview of the steps. Found it here at Moparts years ago:
They installed these at the factory as on piece, dash pad, dash, instruments, et all. I've found it easier just to remove the whole thing and then strip it down on my work bench. Along the top of the dash are four screws usually in the vent openings. You can see them from outside the car looking in. Drop the steering column, remove all the trim around the dash including kick panels. There are two bolts one on each side of the dash, loosen these and the dash will tilt forward. Disconnect the wiring harness from the bulkhead connector, miscellaneous connections at the heater, headlights, dimmer switch, door switches, and the whole thing can be removed. It's a heck of a job, but then you can check, clean, rebuild , repaint anything on the dash. Good luck.
Thanks for the info. Sounds like at least a 2 man job.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor 1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic 1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow 1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top 2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue 2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black 2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
