If you jack up the front end again, let the engine idle and see if the wheels turn right or left from straight ahead w/o touching the steering wheel. That can be adjusted at the gearbox by loosening the casting at the top where the hose attaches and tapping it forward or rearward. DON'T remove it, just loosen the bolts a little. It will weep PS fluid when loose.
