I hope you aren't using a stock block???
-Yes! Using aluminum main caps and light weight rotating parts.. and if it blows, it blows... then again I do think that something else in the engine will let go way before there is any problems with the block itself, though I do plan on upgrading to an aftermarket block later on.. just to give everyone out there a peace of mind
Did a little search about "Step" headers, seems that there is no real proof of advantage using them... So Im gonna go with the 2" headers.. If I loose a few Hp because of that I will not be sad about it...
/Tom
