Quote: Thanks. I did supply him with all new correct bolts. SOme are tube bolts, but it doesn't seem like it was used on this location. THere are 5 tube bolts at other locations and just nuts on the three others. I don't think there was room for the tube bolt here, but I can't find a diagram that shows which one goes where??
it's easy to tell which one goes where because you can't put the short ones in a hole where a long one needs to go and the long ones will hang a inch plus past where a short one needs to be used.
It sounds like whomever installed it didn't put in the stud and just used a long bolt and washer ...
