Rob Cam was not degreed, I can move the rotor CCW so this means I am not locked out. Shall I still drop the timing to 20-22*? I have a new MP electronic ignition in it right now. Shall I try to screw in the idle screws first to see if it will kill the motor like you suggested before turning back the timing, what about the rears leave them for now? Thnx again!!
