You should be able to use any timing set (new) to determine the slop since stock is stock regardless of who makes it (waiting for the arguments here !!)
Oversize chains ?!?!?! All chains are the same - its the top sprocket that's oversize. Which allows you to replace worn chains with any "off the shelf" double roller chain.
A top quality and inexpensive oversize set is available from JP Performance out of Australia. Available through any Motorstate distributor. p/n jpp5606t-lb5
http://www.motorstate.com/site/?ct=131#goto74170
Not all chains or gears are the same for our motors I have experimented with different brands ans style, standard double roller versus True roller, definetly different The latest go around was with a older stock Mopar 3 bolt upper and lower gears with a stock replacemnt Cloyes chain for that appication, it was loose I bought and used a -.005 Cloyes chain, it tighten right up I couldn't switch any parts between the True Roller sets and the stock stuff
