hi, I ran a sprung hub rag disc for years, and bout 1600 # base. never broke any trans then, with the softloc, has a solid hub disc, is when started breaking parts. the softloc is ran at 500# base up to 900# depending on disc wear.launches are at 4400 to 5400 rpm , depending on track.
