Quote:Quote:Be sure that WOT at the pedal is WOT under the hood; a misadjusted throttle cable will prevent the carb from going wide open.Have somebody sit in the car and mat the pedal then see if you can push the carb/linkage back some more. That was the 1st thing I checked John. WOT in car (floored) is also WOT throttle on carb
