I guess I was assuming the heads were MW size. If they aren't MW size then that is a different problem.
A 447 with good MW heads and 15:1 compression will make tons of power if the valvetrain can handle the rpm. Even the 850 carb will make a bunch of power as long as the intake and heads are good.
I ageee to a point but really think more carb would produce more power. I can`t remember any of my motors NOT picking up power w/a bigger carb especially at those higher revs.
72 Dart 470 n/a BB stroker street car `THUMPER`...Check me out on FB Dominic Thumper for videos and lots of carb pics......760-900-3895.....
