The Density altitude is a measure of available oxygen to use. Humidity, temp and barometric pressure are all taken into account to arrive at the Density altitude number. So it doesn't exactly measure altitude, but a combination of the effects of all three. I have found the Walace calculator for converting to zero altitude to be generous. My car doesn't change as much as the category I am in.
