you sure you dont have a leak between the tank and the pump? if you hear a sucking sound, and you see bubbles in the fuel, coming out of the inlet, you might be sucking air close to the pump.
Or it could be the pump itself, I don't think old pumps play well with the ethanol in the fuel.
