incidentally the pistons i have are the Ross 99496 which is a 4.375, 1.238CH piston with a .990 pin and the pin is in the oil ring. i was looking to drop the CR some to run pump gas. i even called ross and asked about minimum crown thickness and where i "might" be able to remove some material to drop the CR. i wrote down the info then promptly lost it
