How does the crank sound when you tap the counterweight with a hammer? I'm curious because I've seen cracked cranks before, pretty sure they were cast, and when you tapped it with a hammer, there was no ring. It was a bit of a dull sound, not the type you have to grab the counterweight to make it go away.
