I just got done looking at a new project, its a 70 barracuda that has a new fiberglass front clip VFN,fiberglass doors already hung, stock front k member, the part I am worried about is the stock floor has been cut out and the cage needs some bars changed out. The cage is mild steel 1 5/8" the door X bars are 1 1/4" which I think is to small for 8.5 cert. The back half looks good but it is a ladder bar along with a set of Chris Alston none adjustable shocks with coils that run the entire length of the shock. The rear end is 8 3/4 stock housing, 489 center section posi rear with 4.88 gears, I believe the axles are stock. The rear of the car is straight with tail lights still in the car, the quarter panels have been trimmed to fit the tires.
So my main questions are what do you guys think?
you can see here where the stock floor is removed but the cage is still tied into it and the subframe. Is this legal I thought you had to have 6x6" plate, this does land on top of the sub frame though.
Thanks for your time
