Can you post some pictures of how you mounted a battery shut off switch using a push rod to move the switch. This for a street/ strip car and was trying to find a place to mount it and where the rod exits through the rear panel. Trying to make it a clean look. Thanks.
No rod, but the key hole position worked for mine....
'70 Cuda,...605 EFI Hemi Street Car (6.20 best pass, 1.33 60ft)
https://www.youtube.com/watch?v=WYw6RA-k5Bk (6.25 at 108.75mph from inside car)
https://www.youtube.com/watch?v=3zQEb9uxFng (6.25 at 108mph from outside car)
'66 Barracuda AWB Stretched nose Blown 440 Car in build stage
'71 Duster Drag Car 400 Low Deck 512 best 6.002 at 115.44mph
https://www.youtube.com/watch?v=Znuo3jMUXTk
