Thaank you very much that was exactly what I was looking for! I like the way the forbbodies only one used the skin off the old door for the patch piece! Thanks again
Yes, that's relatively easy, just keep in mind that the profile of the b-post in a 2 door is different than in a 4 door, so you still can't do it using 2 D doors and just moving the 4 D post rearwards and covering the hole with the partial skin of the 4D. The B-post needs modifications to make it work. Same is true with A-bodies, and on top of that the B-post of the 4 d is way thicker, so that the 2 D sedan rear side glasses won't fit.
Here is some pics of a bit more radical conversion http://www.moparmaniacs.net/belveframe.html
And here is a pic of a converted A-body with the thick B-post: http://kuvia.1g.fi/kuvat/Tapahtumat+2011/FHRA/SonaxSpringNats2011/Camera2/MOP_7902.jpg
Plynouth VIP '67 TT IC EFI
