Quote: Someone told Me that a 65 or 66 B Body with a 6 Cyl and a 7 1/4 Rear has the big bolt pattern and the 1 3/4 wide brakes looking it up they show 1 3/4 wide brake shoes but no drum pt#
Yes that is the application for the drum ... up to 70 ... good luck finding it. The last time I saw them the seller wanted $300 EACH. If you try to put these on redrilled stock axles you will have to make a spacer ring for the center hub.
